Problems working with rotated images in Writer
asked 2019-03-21 19:06:11 +0200
bernardb gravatar image
I have a rectangular image in a LOWriter document. Imagine a 'landscape' image placed on a 'portrait' blank page. Now, if I rotate the image by 90deg to bring it to a 'portrait' orientation, I notice the following behaviour:
  1. I am unable to enlarge the image to fill the page. The size remains constrained to a specific dimension, as if the image was never rotated, and bound by the page dimensions.
  2. If this rotated image happens to be in the middle of a document, playing with its position and size results in very bizarre behaviour. It becomes extremely difficult to position it in the way you want it.
I tried various anchor and wrap settings, but none could solve my problem. The only solution I found was to rotate the image in an external editor before inserting it in my document. I am working with an ODT file with LO 6.2.2. Any clues?
1 Answer
answered 2019-03-22 15:49:23 +0200
Ok so I've just learnt about the bug repository and it seems that the behaviour described above are known bugs, see below.
(1) Resizing Problem
(2) Repositioning Problem
My advice is: avoid using the rotate function for now, unless you have square images!
Login/Signup to Answer
1 follower
Asked: 2019-03-21 19:06:11 +0200
Seen: 365 times
Last updated: Mar 22 '19
