Is there a way to move cells in calc without mouse with keybard?
asked 2019-03-27 23:05:38 +0200
igoryonya gravatar image
I want to be able to move cells by using keyboard, instead of mouse dragging. Is it possible to do it with built-in functionality, or, if not, maybe there is some extension, that will allow to do that?
I don't want to break my hands away from keyboard, when there is a lot of routine processing to do.
1 Answer
1
answered 2019-03-28 00:08:37 +0200
Lupp gravatar image
updated 2019-03-28 00:10:47 +0200
The following description assumes you are not on a Mac and the default shortcut assignments were not changed.
1- Select the CellRange you want to move starting with any cell and using the arrow keys modified by +Shift.
2- Ctrl+X does the cut.
3- Move to the topmost leftmost cell of the range where you want to paste in.
4- Ctrl+V does the paste.
1
Hi
I add other usefull shortcuts:
  • Ctrl+* where (*) is the multiplication sign on the numeric key pad Selects the data range that contains the cursor. A range is a contiguous cell range that contains data and is bounded by empty row and columns.
  • Ctrl+ / where (/) is the division sign on the numeric key pad. Selects the matrix formula range that contains the cursor.
See help site.
Regards
pierre-yves samyn gravatar imagepierre-yves samyn ( 2019-03-28 11:16:32 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2019-03-27 23:05:38 +0200
Seen: 57 times
Last updated: Mar 28
