Avery 5160 label HELP!
I’m trying to print labels from a database in LibreOffice. I’m using Avery 5160 labels but LibreOffice is not showing the 5160 option! Please help
Choose Brand: Avery Letter Size
then Type: 5160
LibreOffice 5.4.5.1 does not have 5160. Was it removed?
w_whalley has it - 5160 really should be showing for you. However, if the label wizard does not seem to be working for your label, you can still try downloading the 5160 template from Avery for Microsoft Word and import it into Writer.
