Drive Letter
How can I make it so that the drive letter is always visible in LibreOffice, no matter what the application? Thanks.
Good question! The drive letter is visible when the cursor is hovered over a document thumbnail in the recent documents panel when LO is first opened, but is NOT seen in the banner at the top of an application after a document has been opened, for example, or in the recent documents list of an application. Unless someone knows of a way to make it happen, it sounds like a needed enhancement.
You mean the whole path to the file? because “drive letter” is only an artifact on Windows, but not on other OSes. Or what specifically you have in mind? An example of wanted display?
See also tdf#82952
See also How to view 'full path' of open document?
