How does one encrypt using Libre? Hoping for 128 encryption or better
asked 2019-07-28 04:11:51 +0100
star8 gravatar image
I need to encrypt my files but can't find a way to do it using Libre. Hoping to find it uses 128
answered 2019-07-28 04:38:48 +0100
Okay, so when I go to save, I found the password option popped up. Still don't know it that means the same thing as "encryption", nor if so, what level of encryption it it. Would be glad to know these things
See for example https://ask.libreoffice.org/en/questi... - or search password secure in the search box above
Please don't use Answer to provide a comment or additional information to your question. Edit your original question, or use a comment as appropriate.
robleyd gravatar imagerobleyd ( 2019-07-28 04:57:03 +0100 )edit
answered 2019-07-28 11:47:27 +0100
lazarus477 gravatar image
Saving the document with a password is what triggers encryption of all the contained data.
Login/Signup to Answer
1 follower
Asked: 2019-07-28 04:11:51 +0100
Seen: 98 times
Last updated: Jul 28 '19
