Problem with MoveCursorToEnd - xlToRight
asked 2019-08-03 13:14:39 +0200
dgulias gravatar image
I'm following the explanation from this PDF: "http://www.openoffice.org/documentati... - page 23" to learn about the difference between VBA and LO Basics.
When I run the code followed bellow I get this error message: "Execution Error BASIC: 35 - MoveCursorToEnd"
Someone can explain me if this is a bug or if is there something wrong in my code?
*my LibreOffice version: 6.2.5.2 (x64)
Cheers
Dim oSheet as Object, oCell as Object
'''get some useful objects
oSheet = ThisComponent.CurrentController.ActiveSheet
'''go to upper slef corner of range
oCell = oSheet.getCellRangeByName("H3")
ThisComponent.CurrentController.select(oCell)
'Find the last cell in the current row
'this takes cursor to cell E3
oCell = MoveCursorToEnd(oCell,"xlToRight")
1
MoveCursorToEnd is a user defined function, which is mentioned at the start of the page:
'''This code fragment makes use of a user defined function
'''MoveCursorToEnd() documented in Appendix B.
Have you included it in your module/library? If so, check if you have copied this function without PDF manual's headers/footers.
SM_Riga gravatar imageSM_Riga ( 2019-08-03 18:45:41 +0200 )edit
1 Answer
answered 2019-08-04 01:06:30 +0200
Thank you SM_Riga.
I didn't create the Support Module. After that everything is working fine.
Cheers
Login/Signup to Answer
1 follower
Asked: 2019-08-03 13:14:39 +0200
Seen: 77 times
Last updated: Aug 04 '19
