Changing tabs filling when making an index doesn't work
asked 2019-08-09 17:33:29 +0100
Ixybus gravatar image
Using styles I've set two headings to test this out and when creating a table of contents I dont' want to fill the tabs with dots, i.e.:
image description
So I create the table and go to the styles tab and modify the contents X style to not fill it with dots but nothing changes. In fact I can't modify anything:
image description
Is this a bug or am I missing something?
1 Answer
1
answered 2019-08-09 17:39:09 +0100
Fill characters for indices/ToC is defined on the Entries tab of the Table of Contents, Index or Bibliography dialog. You select the T of a given level, and edit its properties.
Thanks! Appreciated
Ixybus gravatar imageIxybus ( 2019-08-10 11:22:26 +0100 )edit
Login/Signup to Answer
1 follower
Asked: 2019-08-09 17:33:29 +0100
Seen: 16 times
Last updated: Aug 09 '19
