Problems with LibreOffice Writer (versions 6.2 and 6.3)
asked 2019-08-15 10:07:56 +0200
Yuliya gravatar image
updated 2019-08-15 12:01:20 +0200
I don't know if other people have such a problem but I hope you can help me. The previous version I had was 6.2. And about a month ago I faced a problem with tables: when you insert a table in a word doc, then you can do nothing at all, no copy, no paste - the program doesn't answer and the only thing you can do is to cancel the program forcibly. I thought it could be just some mistake with 6.2 version and today I've installed 6.3, but the same problem again :( don't know what to do... and even in the Writer impossible to select some words/phases/text to copy then... Here is a video file of how it looks when I work there: https://my-files.ru/7q3eub
1 Answer
answered 2019-08-15 10:34:42 +0200
ebot gravatar image
updated 2019-08-15 10:54:51 +0200
Normally, if you work with LibreOffice Writer, you should save your files in ODT format. Make a copy as a DOC file if you want to share it.
You can also look on Bugzilla, if there is a Bug entry. You can also enter a bug yourself.
You can also try to reset your user profile. Read it to the end.
I usually save files in .odt. The problem is that now I just can't work there properly
Yuliya gravatar imageYuliya ( 2019-08-15 11:52:02 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2019-08-15 10:07:56 +0200
Seen: 60 times
Last updated: Aug 15
