Problem with Navigator.
asked 2020-01-17 21:08:13 +0100
dlwy4k gravatar image
updated 2020-01-17 23:57:20 +0100
There are 24 'Headings' in a document. None of them appear in Navigator under Headings. Watched a few YouTube videos regarding Navigator, none helped.
When creating a 'Heading', I use Styles, Heading. System is Ubuntu 18.04 LTS, Libre Office version: 6.3.4.2.0+
Jules applies for a job in a deli. Jules, 22, applies for work in a deli with Natalia and Renaud, the owners. Jules is walking past a deli when she sees a ‘Help Wanted’ poster in the window. Jules enters the deli, approaches the counter where a woman waited with a nice smile and a the name Natalia hand written on an adhesive label. Natalia May I help you? Jules Yes, I hope so. My name is Jules, I am inquiring about the ‘Help Wanted’ sign.
How is this solved?
Could you upload an anonymized sample file showing the problem? Please add also some information about your operating system and the LibreOffice version you are using?
Please do not use Add Answer but edit your original question to enhance the details of your question. Thanks in advance …
Opaque gravatar imageOpaque ( 2020-01-17 22:40:06 +0100 )edit
Just installed 6.3.4.2 on an Ubuntu 18.04 test system and got no problem with visibility in Navigator. Did you already try to test whether your user profile could be the cause of the issue by using Safe Mode?
Test user profile causing issue:
  • Start in Safe Mode using Help -> Restart in Safe Mode and confirm the restart using button: Restart
  • Archive your profile expanding Advanced (click on the word Advanced right above Help button) and click Archive User Profile button
  • Click button Continue in Safe Mode
  • Open a file and test whether the problem is gone
If it works in Safe Mode most probably your user profile is corrupt and you should reset.
Opaque gravatar imageOpaque ( 2020-01-18 00:07:05 +0100 )edit
1 Answer
answered 2020-01-18 00:52:43 +0100
SOLVED Thanks for the help.
Please use the comments, And would be nice to know the solution so other people can find it.
m.a.riosv gravatar imagem.a.riosv ( 2020-01-18 01:03:45 +0100 )edit
Login/Signup to Answer
1 follower
Asked: 2020-01-17 21:08:13 +0100
Seen: 37 times
Last updated: Jan 18
