Does Firebird 3.0’s Window Function work in LO Base 6.4?
I have this query written in SQL:
SELECT “Date”, “Qty”, SUM( “Qty” ) OVER (Order by “Date” ) as “Daily Qty” FROM “Inventori”
Somehow, the command
Sum (“Qty”) Over (Order by “Date”)
is automatically changed by LO Base with
Sum (“Qty”) Over ()
I have also tried to put the command on the normal query design mode, but the same thing happens. Does anybody have an Idea what went wrong?
Thank you.
in upper left area of answer which satisfied the question.
