I have very simple table with a few columns, I need to perform a series of operations on this table and to every other similar table content that I could paste (same columns, different values set) kind of operations that would be simple using a database and stored procedures but I have to use calc:
- obtain the total of a given column grouping for another column, so for example sum column
E
grouping equal values for columnsD
at this point I would have a table/recordset with the calculated results, maybe in another sheet. - filter/sort the dataset with different criteria, it would be a really good thing to be able to save the filters without storing any macro; a quick example could be “sort by column
K
thenE
and consider the rows whereF
> 100” again with the result in another sheet or portion of the page.
Storing these procedures would really help my work when it comes to analyze big amounts of datasets, providing the relevant results conveniently organized in separate sheets. An alternate solution using the macro could be to create a dataset from the table then manipulate it with SQL commands, would that be possible eventually?
