LO Base SQL problems [closed]
asked 2012-05-04 17:36:30 +0100
anonymous user
Anonymous
updated 2013-02-17 06:03:51 +0100
qubit gravatar image
My Query
DECLARE @var
SET @var = 10
SELECT @var
fails to execute. (All are on separate lines)
Also there is no syntax highlighting for DECLARE statement.
Exact syntax error:
syntax error, unexpected $end, expecting BETWEEN or IN or SQL_TOKEN_LIKE
Closed for the following reason question is not relevant or outdated by qubit
close date 2013-03-19 05:57:47.882730
1 Answer
answered 2012-05-04 20:31:44 +0100
mahfiaz gravatar image
What are you trying to achieve?
1
This was just a test query.My goal is to set an entry in one table with SUMed data from column in other table.I already have the SQL code,but the problem is that LO Base will not recognise the DECLARE statement.
DO YOU NEED TO KNOW gravatar imageDO YOU NEED TO KNOW ( 2012-05-05 21:20:42 +0100 )edit
You probably don't need variables at all, just use subquery. But the error is about the select statement. In the select statement you also need to specify the table you are selecting from, e.g SELECT * FROM "MyTable"; But setting the column using variable didn't work (but this is not what you need).
mahfiaz gravatar imagemahfiaz ( 2013-02-18 09:12:53 +0100 )edit
@DO YOU NEED TO KNOW -- Did @mahfiaz's Answer help solve your question? Are you still interested in finding an answer to this question?
qubit gravatar imagequbit ( 2013-03-02 19:24:05 +0100 )edit
Asked: 2012-05-04 17:36:30 +0100
Seen: 523 times
Last updated: Feb 17 '13
