(Solved) LO 4.1 and mate-panel issue
With Libreoffice 4.1 (not with 4.0) when working with table borders (either writer or calc) modifying borders cause mate-panel to disappear (everytime). I type “killall mate-panel” in terminal so the panel comes back. Has anybody the same problem or anybody knows a fix?
SOLVED: Don’t use / disable window compositing. Window compositing caused this.
