There is no scrollbar on my print dialog box for libre documents. I cannot scroll down to get to the print button. I followed you advise to use the alt-F7 keys, but nothing happened. Need help to free the dialog box.
This seems to work: Select the Printer field, Tab once from there (to Properties), then tab once more to select OK, press Enter to print. If you want to cancel then same steps except for enter, but press C for cancel and then press Enter
If you have Windows you can move the print dialog window. Press Alt+Spacebar, Move should be selected so press Enter and you might see a four-headed arrow on the title bar. Movewith mouse or use the arrow keys to move the print dialog box to suit. Click the left mouse to release or, on keyboard Esc.
Next time you print the dialog box might be too high, so use the same key sequence to bring it back down.
Alt+Spacebar works to move the dialog box and expose the whole box. Alt+F7 did not work. Another work around is to right click on any of the icons on the taskbar above the document, then select “print directly”.
If you have Windows you can move the print dialog window. Press Alt+Spacebar, Move should be selected so press Enter and you will see a four-headed arrow on the title bar if the title bar is visible. Move with mouse or use the arrow keys to move the print dialog box to suit. Click the left mouse to release or, on keyboard Esc.
PS. There is a Size option but it won’t make the Print dialog smaller for me, just bigger.
If you are in Windows then going into Settings > System > Display > Scale and layout changing the “size of text, apps and other items” to 100% should make the Print dialog fit a 768 pixel high screen
