calc: |MAX| converted to 0,0000..0000E+00 in save-load cycle
hello @all,
sorry that i have so much questions theese days, life (with calc) is quite 'not so easy' for me theese days ...
i need to play with values to check possibilities for rounding against fp-conversion artefacts,
i tested 1,79769313486232E+308 - see screenshot - being the biggest number calc can handle,
but after save-load of the file a group of cells keyed in as in the green bordered area comes up as in the red bordered area, see the difference between the green and magenta highlighted cells,
you can see the formula for cell A3 in the formula bar, A1 has! been a 'big value' on save, autocalc is! on, i didn't 'tricks around' with the screenshot, just stumbled about something new 'irritating' ...
on superuser.com i'd read that the max limit for a double float value is 1.79769313486231570 • 10^308, but if i key that in a calc cell it's rounded by calc to 1.79769313486232E+308, without any message that this value is too large,
larger numbers are usually simply converted to text? without notice to the user! :-( this not :-( :-(
happened with ver 7.1.0.0.a01 from 2020-09-05, rechecked with ver 6.1.6.3 release, same problem ... could someone retest before i file a bug?
Yes, that is a significand of 1111111111111111111111111111111111111111111111111111 and exponent of 11111111110
The value is not too large, otherwise it wouldn't be accepted as numeric input. The display string of the underlying floating point value though is limited to a precision of 15 digits, that's why it appears rounded.
No. It's the other way around. Text input larger than an acceptable numeric value is not converted to numeric but stays text. Like with any text input, if it's not convertible to numeric or currency or date or time or ... it stays text.
@erAck:
still confused,
cell format 'number standard', keyed in 1,79769313486232E+308, shown as text, cell format changed itself to text,
cell format 'number standard', keyed in 1,7976931348623157E+308, widened decimal range, shown as number (right aligned), cell format changed itself to scientific, shown as '1,79769313486232E+308',
edited! that to '1,79769313486232E+308', still a number, cell format still scientific,
cell format 'scientific', keyed in 1,79769313486233E+308 or any bigger value, shown as number (right aligned), cell format still scientific, cutted down to '1,79769313486232E+308',
different handling of 'too big to nail' values acc. to cell format?
irritating for simple minds (like me) ...
It looks like editing a cell trying to overwrite it with a too large value is refused. I can't say for sure without inspecting things which I won't do right now. But if so it seems like a good feature to me.
