So I have a column in Calc (E) where I want the minimum value to be highlighted. I made my own style which gives the text a yellow background. I then create a conditional format to apply to E2:E9999 where “if cell value =MIN(E2:E9999)” then the format is applied.
At first, it works, and the lowest # in the column, 18, is highlighted on E65. But then 945 is also highlighted on E189, 960 is highlighted on E212, 2128 on E311, 2143 on E334 and 3268 on E364. There is only one other conditional format set, that applies to a single cell elsewhere not in column E and that is working fine so there isn’t any overlap. This seems straightforward enough that I’m at a loss as to what is going wrong.
