LibreOffice build problem in ubuntu 13.10 [closed]
asked 2014-01-05 19:20:34 +0200
kediamanav gravatar image
updated 2014-01-06 11:34:39 +0200
Alexander Wilms gravatar image
This is what I did in order:
  1. Download dependencies using sudo apt-get build-dep libreoffice sudo apt-get install libgnome-vfsmm-2.6-dev
  2. downloaded the source code git clone from the core folder git clone git://anongit.freedesktop.org/libreoffice/core
  3. change directory to that folder and then ./autogen.sh Here is where the error occurs
./autogen.sh: line 1: $':\r': command not found ' '--srcdir=/home/kediamanav/Desktop/libreoffice' '--enable-option-checking=fatal' configure: WARNING: you should use --build, --host, --target configure: WARNING: invalid host type:
  • Running LibreOffice build configuration.
configure: error: cannot run /bin/bash ./config.sub Error running configure at ./autogen.sh line 209.
Please help me with this
close date 2016-02-18 11:30:53.062783
