I am collecting data every minute with a time stamp and temperature. I have had to trim the time stamp using the MId
function. I then select the temperatures which have changes to determine peaks and troughs. This results in two comumns with some times separated by mane cells containing 0. I have tried sorting the column but the sort does not sort the time stamp string.
below is a sample
0 0
0 0
0 10:39
0 0
0 0
0 0
0 0
0 0
0 0
0 0
0 0
11:00 0
0 0
0 0
0 0
0 10:50
10:54 0
10:58 0
11:06 0
0 10:31
0 10:36
0 10:37
0 0
10:49 0
11:11 0
0 11:13
0 10:48
10:51 0
Edit keme: added line breaks to reflect newlines in original post.
