I am having a problem when inserting tables, which is something I must do several times daily. I want one column to be wide for the text description I enter, so I set it under preferences to say 2", and I want all the other columss to be narrow as those will just get a number, so I set those at 0.5". However if I have only 2 other columns to be 0.5", they enlarge by default to go across the page and the width I have chosen is ignored. The choices for relative width, etc are only sometimes available as clickable choices- otherwise they are shaded to not be an option.
I struggled for 30 min to create a usable table for my needs and finally get the table the way I want it. but now:
- is there an option to save this table so I can keep using the same one as my own personal template?
Also, despite creating this slimmed down table, when I cut and paste it into an email all the borders around the cells are lost and the table continues to go way beyond the width of a standard email. What is going on? I didn’t have this problem a few months ago!
Please help! these tables have become such a ridiculous waste of time for me!
