I have a database under MySQL
In Base, I am able to create forms on my database through ODBC
When I create a subform and just add a field of the linked table. I can see the field correctly.
When I leave the edit mode, I have an SQL error that prevent to load the data
Statut SQL: HY000
Code d’erreur: 1000
SELECT * FROM artnouveau.auteurs WHERE ( artnouveau.auteurs.Num Adresse =:link_from_Num Adresse )
syntax error, unexpected NAME, expecting ‘)’ or OR
Maybe it is linked to the space between link_from_Num and Adresse?
What should I do?
