Is there a way to maintain two versions of an image per cell Greyscale and color for printing and email?
Basically when printing Images, one can optimize for the printer - I don’t know how effective that is and I haven’t actually tried that out but color looks much nicer on the computer and that looks a bit drab hence the Q.
I don’t want to waste space on a 2nd column - I’d rather just toggle between the two if that was possible?
And what is the problem to have a “Toggle” button, which toggles between “Hide color-images column / Show grey-images column” and “Show color-images column / Hide grey-images column” ?
the images don’t hide… (and I’d be using two columns so printing may not work as expected - it may shove text off the margin for printing)
That’s not true on my system, which is:
Version: 7.1.1.2 / LibreOffice Community
Build ID: fe0b08f4af1bacafe4c7ecc87ce55bb426164676
CPU threads: 8; OS: Linux 5.3; UI render: default; VCL: kf5
Locale: en-US (en_US.UTF-8); UI: en-US, Calc: threaded
image description
If they don't hide for you, you probably **haven't** anchored 'em **To Cell**
Version: 6.1.5.2 Calc images don’t hide
