Macro Help Base
asked 2021-04-28 03:23:26 +0200
jodybingo gravatar image
updated 2021-04-28 03:25:25 +0200
Hi everyone
With great help from Ratslinger I learned a bi t while instituting a Macro (to send the current records to a report with the push of a button. But I came across another problem that is beyond me.
I have a few other buttons that launch various reports (also using macros). If I leave 1 macro at a time in my database the targeted buttons work fine. However when I put both macros in, one of them produces an error.
The first macro sends the current records to a report:
REM BASIC
Option Explicit
Sub OpenReport
Dim oController As Object
Dim oReportDoc As Object
oController = ThisDatabaseDocument.currentController
if not oController.isconnected then oController.connect
oReportDoc = Thisdatabasedocument.reportdocuments.getbyname("Email_Form").open
Sub PrintCurrent
Dim oForm As Object
Dim oColumn As Object
Dim iField As Integer
Dim oSubForm As Object
Dim oSubSubForm as Object
Dim oSubSubSubForm as Object
oForm = ThisComponent.Drawpage.Forms.getByName("MainForm")
oSubForm = oForm.getByName("Contact")
oSubsubform = osubform.getByName("details")
iField = osubsubForm.getByName("txt-Res ID").Text
if oForm.isNew() Then
MsgBox "New Record - Cannot Print"
Exit Sub
End If
oSubSubForm = oSubForm.getByName("PrintForm")
oColumn = osubSubForm.Columns.getByName("res_id_fk")
oColumn.updateInt(iField)
oSubSubForm.updateRow()
The second sends various buttons to certain reports
Sub PrintReport(oEvent)
Rem Get name of Control
sControlName = oEvent.source.Model.Name
Rem Check for button pushed
If sControlName = "btn1" Then
ReportName = "Party Order Form Today"
EndIf
If sControlName = "btn2" Then
ReportName = "Party Order Form By #"
EndIf
If sControlName = "btn3" Then
ReportName = "Party List"
EndIf
If sControlName = "btn4" Then
ReportName = "Tip List"
EndIf
If sControlName = "btn5" Then
ReportName = "Counter Weekly"
EndIf
If sControlName = "btn7" Then
ReportName = "Event Invoice"
EndIf
If sControlName = "btn8" Then
ReportName = "Email_Form"
EndIf
If sControlName = "btn9" Then
ReportName = "Corp Order E-Mail"
EndIf
If sControlName = "btn10" Then
ReportName = "Theme Email"
EndIf
If sControlName = "btn11" Then
ReportName= "specOinvoice"
EndIf
oContext = CreateUnoService("com.sun.star.sdb.DatabaseContext")
Rem set registered DB name here
oFont = oContext.getRegisteredObject("Reservations JDBC")
dbForms = oFont.DatabaseDocument.ReportDocuments
oAConnection = oFont.getConnection("","")
Dim pProp(1) As New com.sun.star.beans.PropertyValue
pProp(0).Name = "ActiveConnection"
pProp(0).Value = oAConnection
pProp(1).Name = "OpenMode"
pProp(1).Value = "open"
oForm = dbForms.loadComponentFromURL(ReportName, "_blank", 0, pProp())
When I put both macros in one after another I get a Variable Not Defined error on this line. What is the correction needed?
Thanks, Jody W10, LO v7.1.2.2
1 Answer
1
answered 2021-04-28 04:07:38 +0200
Ratslinger gravatar image
updated 2021-04-28 04:41:50 +0200
Deleted the comment. Found the real problem.
At the very top you have defined Option Explicit.
With this you need to Dim all your variables. You did this in the first two Sub's but none in the third. Since the first line of code had the variable undefined (no Dim statement) it generated the error.
Edit:
Dim sControlName As String
Dim ReportName As String
Dim oContext As Object
Dim oFont As Object
Dim dbForms As Object
Dim oAConnection As Object
Dim oForm As Object
Add a beginning of third macro after Sub
Did minor test only because not set with names you are using.
As I am a real newb at this, what are the variables that have to be Dim'd?
jodybingo gravatar imagejodybingo ( 2021-04-28 04:31:31 +0200 )edit
Have you looked at the documentation concerning macros? You need to get some of these basic terms and what the are/do or you will not progress.
LibreOffice Base Guide
Edit:
On the same page as the Base guide and toward the top are the Getting started guides. There is one there for macros.
Ratslinger gravatar imageRatslinger ( 2021-04-28 04:45:49 +0200 )edit
And for further depth in macros you may want to look at Open Office Macros Explained by Andrew Pitonyak. PDF here -> OOME
and
http://www.pitonyak.org/database/Andr...
There is more.
Ratslinger gravatar imageRatslinger ( 2021-04-28 05:51:43 +0200 )edit
Starting to read today
jodybingo gravatar imagejodybingo ( 2021-04-28 15:10:13 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2021-04-28 03:23:26 +0200
Seen: 34 times
Last updated: Apr 28
