LibreOffice build problem in Windows(cygwin)
Fatal error building Windows release (Cygwin)
(1/1) Building module xmlreader
Entering /home/walter/git/libo/xmlreader/prj
[ build CXX ] xmlreader/source/pad
[ build CXX ] xmlreader/source/span
[ build CXX ] xmlreader/source/xmlreader
c:/cygwin/home/walter/git/libo/xmlreader/source/xmlreader.cxx(29) : fatal error C1083: Cannot open include file: ‘sal/config.h’: No such file or directory
c:/cygwin/home/walter/git/libo/xmlreader/source/pad.cxx(29) : fatal error C1083: Cannot open include file: ‘sal/config.h’: No such file or directory
c:/cygwin/home/walter/git/libo/xmlreader/source/span.cxx(29) : fatal error C1083: Cannot open include file: ‘sal/config.h’: No such file or directory
[ build RES ] xmlreader/default
[ build RES ]
make: *** No rule to make target
‘/home/walter/git/libo/workdir/wntmsci12.pro/CxxObject/xmlreader/source/pad.o’, needed by
‘/home/walter/git/libo/workdir/wntmsci12.pro/LinkTarget/Library/ixmlreader.lib’. Stop.
make: *** Waiting for unfinished jobs…
awk: fatal: can’t open source file `C:/cygwinc:/cygwin/home/walter/git/libo/solenv/gbuild/processdeps.awk’ for
reading (No such file or directory)
make: ****
/home/walter/git/libo/workdir/wntmsci12.pro/WinResTarget/xmlreader/default.res Error 2
dmake: Error code 2, while making ‘all’
How can you compile without any error a libreoffice3.5.4.2 on Windows(cygwin)?
Calling gawk from shell, there’s no problem.
How to solve the this problem?
Which environment is used ?
Thanks
Regards
