Hi, i have problems to open documents created by an application called Mega, this is the answer from aplication support…
As you know Hopex is rendering standard RTF code that can be readable by many RFT readers such as Gmail RTF readers, MS Office, open Office… so, if LibreOffice cannot read correctly our RTF documents then maybe there is something wrong with their code.
You can test by opening a generated RTF document with a standard RTF reader such Gmail RTF reader you will find that all the diagrams are shown correctly.
Example file:
Nota: OpenOffice and google docs opens the file without problem
Best regards
Pedro Esteban
