How can I get offline help for en_AU locale?
What’s the point of going to the trouble of downloading and installing OFFLINE Help if, when I click on “Help”, I still get connected to ONLINE Help? HOW do I access/use Help OFFline? LibreOffice Version 4.3, running on Windows 7 English (but the same question also applied to earlier versions running on XP).
I downloaded and installed Offline Help, expecting that I would then be able to access and USE it, but both the avenues into Help that I have been able to find still open Online Help from a remote server, in my browser. What was the point of downloading the Offline version? Else: HOW DO I ACCESS IT?
Related questions here, here, and here. There is no helppack for the en_AU locale. In order to use offline help it will be necessary to set your locale to en_GB or en_US and install the related helppack. Please raise an enhancement bug for offline help relating to this specific locale if this issue is important to you.
I understand that the contents of a downloadable and locally installed help pack will only display if the User Interface (UI) is set to use the same language as the help pack. For example, I have the user Interface set to English (UK), and the help to English- (UK), LibO 4.2 and 4.3 Ubuntu 12-04 and Linux Mint 17. The help is working offline. There have been several questions on this same topic.
You set the Language using TOOLS > OPTIONS > LANGUAGE SETTINGS > LANGUAGES. What version of English are you using and what version of English help pack? Have not tried this problem on XP in case it works differently, or that there is is a known bug. Hope this helps Peter
In XP it works the same way. Perfectly fine off-line help. I have user language (US-English) and help file (US-English) to be the same. The user interface must match the language of the help file.
Thank you to both petermau and ROSt52.
My libre office settings are:-
User interface: Default - English (UK)
Locale setting: Default - English (Australia)
User interface does not give the option to set it to English (Australian).
I don’t know where to find, hence how to check, or set, the help pack language option.
Any further clarification will be gratefully received.
Thanks,
Grumpy.
