Split page to insert 2 contents using LO Writer
It’s hard to explain this problem with word, maybe this picture can clear you out for what I want.
So how can I make this happen?
I understand from your drawing that you want to have 2 columns of text on one page. If so please do:
Insert > Section > tab: Columns > select the number of columns you want to have and set all the way you want to have it.
I recommend addtionally to have a look at the free guides which you can download from http://www.libreoffice.org/get-help/documentation/
Thank you very much for the answer, yeah it’s working. :slight_smile:
If you wish to have two pages on one sheet, you can also change the complete page into two halves using Page Styles. Format > Page > Column 2. This would work on multiple page documents.
I agree that the free guides are very useful in explaining this type of problem…
Thank you very much for the answer, yeah I should find it in Google first, but I can’t find any suitable keyword that get me straight to the answer. But thanks anyway. :slight_smile:
