replace identical values in same column with unique identifier [closed]
asked 2014-11-07 14:15:15 +0200
bennypr0fane gravatar image
I have a worksheet where lots of cases have the same value in that column (B) that is actually supposed to serve as a primary key when importing this file into a database, i.e. no value in this column/variable must be the same as any other, so that value can serve to identify the case. Here's a screenshot:
look at column B
How can I automatically replace all values in this column with numbers 1-207?
close date 2016-03-05 22:10:57.026562
1 Answer
answered 2014-11-07 14:34:42 +0200
karolus gravatar image
Hallo
fill Column B with Formula: =ROW()
fülle Spalte B mit der Formel =ZEILE()
Karolus
Is it possible to fill each cell of the whole column with the same content in one step, or define a function to be valid for the whoel column, or would I just have to do this 207 times over? Also If I use this method, won't the cell numbers change if I rearrange the lines? The value in the cell shouldn't be affected by changing the position of the line.
bennypr0fane gravatar imagebennypr0fane ( 2014-11-07 22:39:59 +0200 )edit
1 follower
Asked: 2014-11-07 14:15:15 +0200
Seen: 445 times
Last updated: Nov 07 '14
