How to create a water fall chart?
asked 2015-04-06 23:43:25 +0200
isolarworkx gravatar image
Dear all, Can you please let me know how to create a water fall chart in libreoffice?
Thanks, Ali
1 Answer
answered 2015-04-07 02:58:32 +0200
m.a.riosv gravatar image
An excel template, that seems work fine with LibreOffice
Water fall chart template
@m.a.riosv - I developed a while ago my own template for water fall charts in Calc. Work fine. However. I like to add horizontal lines between to column elements. Is there a way in Calc do do this?
ROSt52 gravatar imageROSt52 ( 2015-04-07 03:06:35 +0200 )edit
Hi @ROSt52, there is an option in Formatting Series, but it works between the same serie's data, so I guess it depends on how chart is organized. Or maybe and stock column with line, generating a serie for the line with other data series.
m.a.riosv gravatar imagem.a.riosv ( 2015-04-07 14:31:49 +0200 )edit
@m.a.riosv thanks for the hint I will try it next time.
ROSt52 gravatar imageROSt52 ( 2015-04-14 03:27:37 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2015-04-06 23:43:25 +0200
Seen: 671 times
Last updated: Apr 07 '15
