Build in same machine, different path bombs
asked 2015-05-02 01:46:03 +0200
arielCo gravatar image
updated 2015-05-02 01:46:42 +0200
I tried to copy my build directory to an SSD hoping to make it faster, by copying .gitand getting new sources:
    mkdir .ccache
    export CCACHE_COMPRESS=1 CCACHE_DIR=./.ccache
    ccache -M 5G
    rsync -avx  /mnt/stuff/src/libreoffice/core/.git .
    git pull
    git reset --hard
    ./autogen.sh --with-parallelism=8 --without-krb5 --without-gssapi --without-java --without-help --disable-odk CFLAGS='-O3 -march=native -pipe' CXXFLAGS='-O3 -march=native -pipe'
    export | grep CCACHE
    time nice make
(I had to do `git reset --hard` because otherwise Git would tell me it's "up to date". I'm a zero with Git.)
But the build bombs out trying to build an external tarball:
ariel@section9:/mnt/windows/libreoffice-src/core/workdir/UnpackedTarball/firebird/gen $ /usr/bin/ccache g++   -I/mnt/windows/libreoffice-src/core/workdir/UnpackedTarball/libatomic_ops/src   -DBOOT_BUILD -I../src/include/gen -I../src/include -I../src/vulcan -DNAMESPACE=Vulcan -DNDEBUG -ggdb -DFB_SEND_FLAGS=MSG_NOSIGNAL -DLINUX -DAMD64 -pipe -MMD -fPIC -fmessage-length=0 -O3 -fno-omit-frame-pointer  -pthread   -I/mnt/windows/libreoffice-src/core/workdir/UnpackedTarball/boost -L/mnt/windows/libreoffice-src/core/workdir/UnpackedTarball/boost/source/lib   -I/mnt/windows/libreoffice-src/core/workdir/UnpackedTarball/icu/source -I/mnt/windows/libreoffice-src/core/workdir/UnpackedTarball/icu/source/i18n -I/mnt/windows/libreoffice-src/core/workdir/UnpackedTarball/icu/source/common -L/mnt/windows/libreoffice-src/core/workdir/UnpackedTarball/icu/source/lib   -fno-rtti -fno-rtti -fno-rtti  -c ../src/jrd/gds.cpp -o ../temp/boot/jrd/gds.o
In file included from ../src/jrd/gds.cpp:59:0:
../src/jrd/../common/utils_proto.h:77:2: error: #error dont know how to compare strings case insensitive on this system
../src/jrd/../common/utils_proto.h:94:2: error: #error dont know how to compare counted length strings case insensitive on this system
../src/jrd/gds.cpp: In function ‘void gds__trace_raw(const char*, unsigned int)’:
../src/jrd/gds.cpp:1078:27: warning: ignoring return value of ‘ssize_t write(int, const void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
  write(file, text, length);
What am I doing so terribly wrong?
1 Answer
answered 2015-05-02 18:31:21 +0200
m.a.riosv gravatar image
I think better ask in dev mailing list.
http://nabble.documentfoundation.org/...
Login/Signup to Answer
1 follower
Asked: 2015-05-02 01:46:03 +0200
Seen: 86 times
Last updated: May 02 '15
