Problem Filtering out Duplicates
asked 2015-11-26 04:14:31 +0200
Shani92 gravatar image
Hi,
I have a large data seet. I want to remove any rows for which the ID number (listed in the first column) has previously appeared. If this works correctly I expect about 40% of the entries to be removed.
However, when I use Data->Filter->Standard Filter-> Option-> Remove duplicates ALL my data points are being removed.
I'm not sure why this is happening. I would include the screenshot or attach the data but I do not correctly have enough karma points.
Thanks
1 Answer
answered 2015-11-26 16:13:17 +0200
w_whalley gravatar image
I think this will work.
Select the cells only in your ID column. Choose Data/Filter/Standard Filter Filter selection criteria Column = . ( a single period) Options checked: Regular expression, No Duplications Click OK This only hides the duplicate cells. Select the whole block and copy/save to another location to remove the hidden cells.
That did not work. Thank you for trying though
Shani92 gravatar imageShani92 ( 2015-11-30 01:00:50 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2015-11-26 04:13:57 +0200
Seen: 237 times
Last updated: Nov 26 '15
