JRE Problem with mac os 10.11.3
asked 2016-03-06 18:07:28 +0200
this post is marked as community wiki
This post is a wiki. Anyone with karma >75 is welcome to improve it.
Hi Macbook Pro 13inch without retina display. My os is 10.11.3 I have installed LO I downloaded and installed javaforosx.dmg and JavaForOSX.pkg I have also downloaded and installed jre-8u73-macosx-x64.dmg. Yet when i open LO and start creating database, i get an error message saying that LO needs jre ... please install it... or words to that effect.
Someone please guide me to the correct steps Thanks
In brief, you need to install a JRE that matches the bit-size of LO rather than (possibly) your OS. Next, select that JRE version (if not already selected) within LO.
Alex Kemp gravatar imageAlex Kemp ( 2016-03-07 12:38:49 +0200 )edit
1 Answer
answered 2016-06-23 15:00:29 +0200
Hi. Try LibreOffice -> Preferences -> LibreOffice -> Advanced -> select the Java version you've installed.
Login/Signup to Answer
1 follower
Asked: 2016-03-06 18:07:28 +0200
Seen: 1,603 times
Last updated: Jun 23 '16
