exclude strings of words using wildcards
asked 2016-03-23 15:22:40 +0200
CHGN gravatar image
updated 2016-03-23 15:24:05 +0200
Hi community,
I cannot seem to come up with the appropriate wildcard (I suppose it must be [!]) which would exclude from the expression
⟨argument[oales]{1,4}⟩
the following three words
argumentos argumenta argumentas
In other words, I would like it to find only the following three words
argumento argumental argumentales
so maybe it's the expression ⟨argument[oales]{1,4}⟩ which is not appropriate to begin with.
Note that I am actually trying to find a 'pattern expession' so that I can use it with any other morphological word family; thus, those three words are mere examples. I would use this pattern in a macro, and possibly in Find and Replace option, to implement replacements in batch.
Hope to hear news soon. Thank you so much in advance.
answered 2016-03-23 16:37:57 +0200
pierre-yves samyn gravatar image
updated 2016-03-23 16:39:55 +0200
Hi
If I understand well you can search for:
\bargumento\b|\bargumental\b|\bargumentales\b
Explanation: \b for Word boundaries
Regards
answered 2016-03-23 17:23:16 +0200
oweng gravatar image
Bearing in mind that pattern matching, as the term indicates, is best used to find rather than exclude patterns, the following will match only the desired terms:
argument(o[^s]|al(es)?)
1
Hi @oweng
Nice, but may I suggest: argument(o|al(es)?)\b
(not to select the space after the word, to find the the word at the end of the paragraph, to avoid selecting the word followed by a letter other than s, etc.)
Regards
pierre-yves samyn gravatar imagepierre-yves samyn ( 2016-03-23 17:59:16 +0200 )edit
Thanks pierre-yves. That is a distinct improvement for the reason you indicate. I am still thinking of strings rather than words :-)
oweng gravatar imageoweng ( 2016-03-23 18:08:21 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2016-03-23 15:22:40 +0200
Seen: 110 times
Last updated: Mar 23 '16
