Maybe consider creating a macro in basic to do the formatting.
Instead of converting the csv file to an ods, and then formatting the ods file, you can start LibreOffice from command line or bash to open the csv file and then run your formatting macro.
You might be able to create most of your formatting using the macro recorder, although its sometimes better to write the macros in basic and not rely on the recorder.
Using this method from Windows bat file (which you can modify to run from bash).
"C:\Program Files\LibreOffice 5\program\soffice" --headless --infilter="Text - txt - csv (StarCalc):44,34,0,1,1/1" "Untitled 10.csv" "macro:///FormatCSVtoODS.FormatCSVtoODS.FormatCSVtoODS()"
Above line will load the csv to LO and then run the FormatCSVtoODS sub in the Library and Module of the same name.
Example below will only set the top row to bold and freeze the top row of the sheet.
REM  *****  BASIC  *****
Option Explicit
Sub FormatCSVtoODS()
	Dim oDoc As Object
	Dim oSheet As Object
	Dim Args(0) As New com.sun.star.beans.PropertyValue
	Dim sDirectory As String
	Dim sFileName As String
	oDoc = thisComponent
	sFileName = oDoc.Title
	sDirectory = replace(oDoc.Location, "%20", " " )	'	Allow for spaces in name as %20
	sDirectory = replace(sDirectory, sFileName, "" )
	sFileName = left(sFileName, instr(sFileName,".") - 1)
	oSheet = oDoc.Sheets(0)
	'	Make the sheet active
	oDoc.getcurrentController.setActiveSheet(oSheet)
	dim document   as object
	dim dispatcher as object
	document   = oDoc.CurrentController.Frame
	'	Apply formatting, these were recorded macros
dim args1(0) as new com.sun.star.beans.PropertyValue
args1(0).Name = "ToPoint"
args1(0).Value = "$A$1:$D$1"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args1())
dim args2(0) as new com.sun.star.beans.PropertyValue
args2(0).Name = "Bold"
args2(0).Value = true
dispatcher.executeDispatch(document, ".uno:Bold", "", 0, args2())
dim args3(0) as new com.sun.star.beans.PropertyValue
args3(0).Name = "ToPoint"
args3(0).Value = "$A$2"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args3())
dispatcher.executeDispatch(document, ".uno:FreezePanes", "", 0, Array())
	'	End of formatting
	'	Save the file as calc .ods format
	Args(0).Name = "Overwrite"
	Args(0).value = false
	On Error Resume Next
	oDoc.storeAsURL( sDirectory & sFileName & ".ods", Args)
	On Error Goto 0
	thisComponent.Close(true)
Edit to add alternate method:
The basic macro could be included in a separate .ods file, but then you probably don’t want to use --headless option as you need to accept the file has macros, or always enable macros which is probably a bad idea.
Attached example.FormatCSVtoODS.ods
Call from windows bat file is changed to:
"C:\Program Files\LibreOffice 5\program\soffice" "D:\UserData\Mark\Desktop\Calc\FormatCSVtoODS.ods" "macro://FormatCSVtoODS/Standard.FormatCSVtoODS.FormatCSVtoODS(Untitled 10.csv)"
A better method might be to put all the function of the bash script into the ods file and create a user interface in LibreOffice basic to select the files to process.
