Custom animation is triggered after a few clicks
Hi,
I have found that some slides has the following problem:
I have to click serveral times so that effects are triggered. It’s a strange because only happens in some slides with very same configuration.
Is it a bug?
I’m using
Versión: 5.1.5.2
Id. de compilación: 5.1.5.2-6.fc24
Subprocesos de CPU: 4; Versión de SO: Linux 4.7; Renderizado de IU: predeterminado;
Configuración regional: es-AR (es_AR.UTF-8); Calc: group
Thanks in advance!
My guess is that the slide transition or an animation is still going on when you’re began clicking. Please check.
If this is the answer for you, please click “Close”.
