LibreOffice will not open on Sierra
Updated my MacBook Pro to Sierra. Updated LibreOffice to the latest build 5.2.1.2. LibreOffice will not open. It just bounces in the dock for several seconds, then, goes away. Then, I get a crash log. Is there a fix for this? Is someone working on a fix for this? Thanks.
Same problem, see “LibreOffice 5.2.1 & 5.1.5 crashing after upgrading to macOS Sierra (10.12)”. All I know is that a fix is being worked on.
https://bugs.documentfoundation.org/show_bug.cgi?id=100994
