Hello.
I’ve been using the cross-reference tool to refer to figures in my document. It inputs the number I choose (if I remember to highlight number everytime). However, I’ve gone and inserted a new figure earlier in the document, hit update and nothing happened. The tool puts a number in but does not give it a hyperlink to the relevant figure.
For me the cross reference updates without any action. Don’t select the caption - just use Insert - Cross reference, select Illustration from the list, select the illustration that you want to refer to, and that should do it.
If this answer helped you, please vote it with
(here on the left). That will help other people with the same question.
