Regular Expression Limitation with Paragraph Replacement
asked 2016-11-30 13:23:00 +0100
Gameranand gravatar image
I got into a situation where it seems like there is no way forward. image description
After : there is paragraph break which I want to remove but when I search using :$, it searches just fine but no matter what I put in replace box, it doesn't remove the paragraph break.
I found that When I search :$ then it will search a paragraph break after : but won't remove the paragraph mark. Tabs, newlines, paragraphs \t \n $
So any alternative to this. I tried with Alt Search as well but it won't let me do the thing either.
1
answered 2016-11-30 14:17:31 +0100
Lupp gravatar image
updated 2016-11-30 14:23:10 +0100
I do not write in Hindi or anything in 'Complex Text Layot' but I tested a bit just now with AltSerach V1.4.1 in LibO V5.2.2. (The previos AS V1.4 does not list LibO V5.)
You know that AltSearch is using a slightly extended and different coding?
$ is a "zero-width-lookahead-assertion" functionally while \p is denoting the next-paragraph-mark itself. Found groups (parentheses used in the search string) are denoted \1, \2 and so on in AltSearch.
Seraching for (:)\p the correct substrings were found - also if the text was inside a right to left sequence. Using \1 as replace string then replaced the combined finding with the colon allone and the next-paragraph-mark was deleted.
You my friend, are a lifesaver. :-)
Gameranand gravatar imageGameranand ( 2016-11-30 14:22:48 +0100 )edit
answered 2016-11-30 14:01:52 +0100
RGB-es gravatar image
updated 2016-11-30 14:05:10 +0100
Indeed, you cannot cross paragraph borders with the build-in regular expressions engine. That is: you can search for a paragraph break alone or for something that's at the en of a paragraph, but not both at the same time.
Try with the AltSearch extension instead that provides more options (maybe you need to use the [::BigBlock::] tag provided by the extension)
And how do I use that Big Block feature. Sorry I haven't used that extension that deeply. I have only used it for regular expression which gets too complicated using normal Find and Replace.
Gameranand gravatar imageGameranand ( 2016-11-30 14:13:58 +0100 )edit
Login/Signup to Answer
1 follower
Asked: 2016-11-30 13:23:00 +0100
Seen: 186 times
Last updated: Nov 30 '16
