LO Calc Basic (Macro): How to work with integers
asked 2017-01-07 18:17:18 +0200
Escain gravatar image
updated 2017-01-07 21:12:48 +0200
Question
I am trying to write a very simple function equivalent to this C/C++/Java/..., but in LO Calc Basic
int test( int v) { return v / 10; }
// test(3) -> 0
// test(6) -> 0
// test(14) -> 1
// test (18) -> 1
// test(22) -> 2
The problem is, Calc seem to Ceil or Round integer operations instead of the expected flooring.
function test( v as Long) as Long
    test = v/10
end function
// test(3) -> 1
// test(6) -> 1
I also tried to create a floor function (Math.Floor is missing for any reason in LO) but does not help:
function floor( v as Double ) as long
    floor = v-(v Mod 1)
end function
    test = floor(v/10)
end function
This unfortunately and without rational, return also the ceil value.
EDITED: Ok, it seem my "floor" function is hidden by the Calc FLOOR function. So I still don't know how to write a working Floor function. Why Calc don't have just the normal Math.floor()?
Thanks for any help.
1 Answer
answered 2017-01-07 20:48:11 +0200
Ok, after some more research, I found a trick to have a "floor" function and making this code:
function Int( v as Double ) as Long
dim aux as Long
aux = v
if aux > v then
    Int = aux-1
else
    Int = aux
endif
end function
function test ( v as Double ) as Long
    test = Int( v / 10)
end function
Login/Signup to Answer
1 follower
Asked: 2017-01-07 18:17:18 +0200
Seen: 366 times
Last updated: Jan 07 '17
