I need to save my LO calc file as a comma delimited CSV to import into another system.
It requires a return at the end of each row but the character is incorrect.
Is there an option to change the row end character?
What is the default character? It appears to be a normal return but if I delete it and replace with a normal return the import works fine.
Thanks for your help.
Kevin
