Problems with Active Connection [closed]
Using a split database, I am trying to run a text file containing an sql command using a push button in a form.
Here the macro: sub dosql if IsNull(ThisComponent.CurrentController.ActiveConnection) then ThisComponent.CurrentController.connect endif txtfile="/home/xxxx/Desktop/sqls.txt" f1 = FreeFile() Open txtfile for Input as #f1
Do while NOT EOF(f1) Line Input #f1, s rem MsgBox(s) oStatement = ThisComponent.CurrentController.ActiveConnection.createStatement() oStatement.execute(s) Loop end sub
When I run this macro using the Tools, Macros, Run Macro command, it works.
However, when I assign this macro to a push button in a form. I get the following:
When I check to see if there is an active connection in the database by right clicking on the main screen on the Database connection I get this: Error code: 1000
The driver class 'org.hsqldb.jdbcDriver' could not be loaded.
Maybe that is part of the problem. Please excuse my ignorance.
