I am creating a template for use in writing academic papers. The template makes use of numbered paragraphs for examples, like:
(34) This is an example.
If I insert a cross-reference to (34) it will include the parentheses just as this sentence demonstrates, no matter what option I choose in the cross-reference window. The problem is sometimes I need to refer to sub-examples like (34a), but LO insists on displaying them as (34)a, which is dumb. I figure if I could just insert a reference to the number, without the parentheses, then I could manually add the letter ‘a’ (or maybe insert that as a xref too?) And then manually add the parentheses as well.
