anyone having this problem. need help. need a solution.
Using the term “app” makes my gut feel that you are on Mac OS X - if that’s true, be aware that Mac OS X requires JDK instead of JRE.
Use Split-DB. It’s very reliable.
Please check UNDER:
Tools >> Options >>Advanced >> Java Options //
Java Version 1.8.0_221 (Oracle Corp.) is checked.
Regardless, if database used is HSQLDB you still need to install Java.
