Im trying to open a powerpoint presentation I’ve been working on and I can only get it to open in the full screen mode…how do I open it so I can continue to add slides?
If your PowerPoint file has an extension of “pps” change it to “ppt” and then you should be able to open it for editing.
John,
Many thanks…that suggestion does the trick perfectly…now I know…very much appreciated!
Please mark John’s answer as Correct by clicking on the check mark to the left of the answer (so that your question is marked as Answered), and up-vote it
