Writer master document using reportbuilder output, need to remove pagebreaks
Hello
I need to create a document consisting of some header text, then the output of two Base ReportBuilder (RB) files. I am currently using a Writer master document for this. I can load the two subdocuments successfully with silent update to refresh content. My problem is the tables generated in RB have ‘break before’ attribute, so there is a page break before each subdocument; cannot find anyway to change this in RB. I want to change the tables BreakType to NONE.
The code below tries to do this, but does not seem to be working as the saved document still has the page breaks. I have tried a couple approaches, neither works. I can manually change the output to remove the page break, but need this automated. Any suggestions?
Using LO Version: 5.3.7.2
    REM Variable declarations not shown for brevity
	Set oController = CurrentDb.Document.CurrentController
	'Create registration base file
	pvArgs(0).Name  = "Hidden"
	pvArgs(0).Value = True
	Set odReport = oController.loadComponentWithArguments(com.sun.star.sdb.application.DatabaseObject.REPORT, acCampRegRep, acViewNormal, pvArgs)
	pvArgs(0).Name  = "Overwrite"
    odReport.storeAsURL(acCampRegURL, pvArgs)
	odReport.dispose()
	'Create registration invoice file
	Set odReport = oController.loadComponentWithArguments(com.sun.star.sdb.application.DatabaseObject.REPORT, acCampInvRep, acViewNormal, pvArgs)
    odReport.storeAsURL(acCampInvURL, pvArgs)
	odReport.dispose()
	'Open MASTER file and update links
	pvArgs(0).Name  = "UpdateDocMode"
	pvArgs(0).Value =  com.sun.star.document.UpdateDocMode.QUIET_UPDATE
	Set odReport = StarDesktop.loadComponentFromURL(acCampTplURL, "_blank", 0, pvArgs)
	'Set textflow on ingested subdocuments
	Set oTables = odReport.getTextTables()
	Set oTable = oTables.getByIndex(0)
    oTable.BreakType = com.sun.star.style.BreakType.NONE
'    odReport.getTextTables().getByIndex(0).BreakType = com.sun.star.style.BreakType.NONE
    odReport.getTextTables().getByIndex(1).BreakType = com.sun.star.style.BreakType.NONE
	odReport.Select(oTable)
    oCurs = odReport.getViewCursor()
 	oCurs.BreakType = com.sun.star.style.BreakType.NONE
    odReport.storeAsURL(acCampOutURL, pvArgs)
After reading "OpenOffice.org Macros Explained " by Andrew D. Pitonyak, I reworked my code to make use of TextFrames and Bookmarks. Now I generate the report, extract required table(s), then paste into the output document at a bookmark location within a frame. This does exactly what I need.
Working code below.
'Routine to import block from generated report
Sub InsertReportBlock(odOutput As Object, sReportName As String, sTables As Object, sBkmrkName As String )
   Dim odReport, oController, oTable, oInCursor, oOutCursor, oBlock, oBookmark
   Dim pvArgs(2) As New com.sun.star.beans.PropertyValue
   Dim i
   Set odReport = createunoservice("com.sun.star.text.TextDocument")
   Set oTable   = createunoservice("com.sun.star.text.TextTable")
   'Generate reports for reservation details & invoice
   pvArgs(0).Name  = "Hidden" : pvArgs(0).Value = True
   Set odReport  = oController.loadComponentWithArguments(com.sun.star.sdb.application.DatabaseObject.REPORT, sReportName, acViewNormal, pvArgs)
   Set oInCursor  = odReport.CurrentController.getViewCursor()
   Set oOutCursor = odOutput.CurrentController.getViewCursor()
   Set oBookmark  = odOutput.getBookmarks().getByName(sBkmrkName)
   'Loop over list of table names
   For i = LBound(sTables) To UBound(sTables)
      'Copy report content
      Set oTable = odReport.getTextTables().getByName(sTables(i))
      odReport.CurrentController.select(oTable)
       oInCursor.gotoEnd(True)  'Move to the end of the current cell.
        oInCursor.gotoEnd(True)  'Move to the end of the table.
        Set oBlock = odReport.CurrentController.getTransferable()
      'Paste at bookmark
        oOutCursor.gotoRange(oBookmark.getAnchor(), False)  'Move the cursor to bookmark location
        odOutput.CurrentController.insertTransferable(oBlock)
     Next
Exit_Function:
   odReport.dispose()
