I’m new to using LibreOffice and while I like what I see so far, I have several big issues with it. I’ve tried the official help website and general googling but couldn’t find any satisfactory answers…
Is there a dictionary that you can use to define words? (In Microsoft Word, you can right-click a word and choose “Look up.” I can’t find a similar function in LibreOffice.)
How do I turn off the Auto-suggestion that suggests words as I type? I found tutorials on how to disable it, but all the tutorials seem to be outdated and now inaccurate, so they don’t help.
How do I install the built-in offline Help? Occasionally I run into a pop-up saying “You may either install it from our website or your system’s repositories, or read an online version,” but I can’t find where the installer is located either on the website or my system.
I’m using LibreOffice v. 6.4.5 on Windows 10.
