LibreOffice does not have “script” font and I need such font on my LibreWriter.
Your question has nothing to do with LibreOffice because LibreOffice simply picks fonts installed system-wide, see robbleyd’s answer.
Install the font on your operating system by whatever means it uses. Then close and restart LibreOffice and it should pick up the new font(s).
If this answer helped you, please accept it by clicking the check mark
to the left and, karma permitting, upvote it. If this resolves your problem, close the question, that will help other people with the same question.
and if Libre Office does NOT pick up the new fonts?
Here’s what LIbreOffice 6.1 sees of my 100+ fonts: 8 or so fonts total.
permission problem! fonts will show up in LibreWriter if permissions on the newly created folders are changed:
# change permissions:
chmod -R ugo+rx /usr/share/fonts/
# now run this:
# build font information cache files
fc-cache -f /usr/share/fonts/
checkout my tutorial here: » Fedora CentOS RedHat – adding new fonts to the system for LibreOffice to use | dwaves.de
