After update to 5.0.3 from 4.3.3 there is a problem with italics in Writer: There are “dots” underneath some letters in italics when I load documents created with older versions of LO. Any idea what is happening?
Have the fonts in old documents installed? Is the anti-aliasing option Menu/Tools/Options/LIbreOffice/View enable?
Yes, the anti-aliasing option is enabled. I’m not sure what you mean regarding the fonts. Thank you for your reply anyway.
Changing the OpenGL option has some effect?, It’s needed to close completely LibreOffice for it takes effect.
Yes, thank you. Unticking the “Use OpenGL for all rendering” has solved the problem.
Unticking the “Use OpenGL for all rendering” has solved the problem (→ Menu/Tools/Options/LIbreOffice/View).
