Suggest debugging in Menu Tools SQL, if you are not already doing this.
Suggest quoting identifiers. While this is not always necessary, it serves to clarify distinctions from reserved words at times. ("", `` or [] in Embedded HSQLDB 1.8). (Back tick quote in MariaDB or MySQL).
If it doesn’t work, break it down until it does, e.g. try,
SELECT zip As xx
FROM families INNER JOIN participants ON families.familyid=participants.familyid;
or even simplify to
SELECT zip As xx FROM families;
Until it works, then build it back together one step at a time, testing as you go. Use a text editor in another window to keep your code so you can cut and paste to go backwards and forwards in your construction.
Here is a working HSQLDB example for you:
In this database: Lookup3.odb
SELECT "Name" As "N", "Product" As "P"
FROM "Companies" INNER JOIN "Products"
ON "Companies"."Company ID"="Products"."Company ID"
ORDER BY "Name";
This also works in this case:
SELECT Name As N, Product As P
FROM Companies INNER JOIN Products ON Companies.[Company ID]=Products.[Company ID]
ORDER BY Name;
Returns status:
Command successfully executed.
And outputs:
Big Dog Products,Bark collar,Big Dog Products,
IBM,pc,IBM,
IBM,IBM 370,IBM,
Intel,8086,Intel,
Intel,8080,Intel,
Main Street Tools,screw driver,Main Street Tools,
Main Street Tools,wrench,Main Street Tools,
Rayco,diode, vaccume tube,Rayco,
Toyota,takoma,Toyota,
Toyota,echo,Toyota,
