Base date format problem - swapping DD/MM
I created a new embedded Firebird-database. I defined in this database a table with a field ‘DATE1’ in it. Now I want to add data to this table. Double click on this table name, I fill in a date in this field like 10/05/19, the system changes that to 05/10/19. What is going on with Firebird embed? With HSQL in the past (older versions of LibreOffice), a date like 10/05/19 stays 10/05/19. In Belgium and France we note dates as DD/MM/YY.
This swapping happens only when Day<=12. For example 13/05/19 stays 13/05/19, but 12/05/19 becomes 05/12/19. Very strange.
My local settings Options/Language Settings are:
-User Interface: Default - English (USA)
-Locate setting: Dutch(Belgium)
-Date acceptance patters: D/M/Y
Libreoffice v 6.1.5.2 on Windows 10 and Firebird-database created and embedded in Base.
What can I do that 10/05/19 stays 10/05/19 (DD/MM/YY)?
Hmm - you did no tell which format you specified for the column at definition time and whether you changed on the table and all in all your definitions are not constructed to avoid ambiguity [10,05] could be D or M or Y and 19 could be or Y or D. So I recommend to stick to ISO code (YYYY-MM-DD) on all levels and leave everything else to a later representation of your data.
I specified nothing special at the definition only field-type:DATE. I assumed that a correct format is DD/MM/YY because the Locale Settings is Dutch(Belgium) and the Date pattern is D/M/Y. I did also a test with a specified user format: Dd/MM/YY, with the same result: swapping. I did tests with other Local Settings (France) with the same result: swiping D/M. In fact you have only problems when you use a / as separator. Other separators German (.) or Dutch Netherlands (-): no swapping so ok. This non-consistent behaviour means a bug which was not there in older Libreoffice version.
Please check in design mode, whether Format dialog shows really “Dutch(Belgium)” in category “Language”. On my Base there is no such conversion, even if I do not specify an format code explicitly - but I use 6.2.3.2 on Linux.
Yes I checked Locale setting: “Dutch(Belgium)”: is on, but also with French(France)- settings we have the same problem: swapping M/D.
I did not talk about Locale in Tools - > Options … but in Language setting in base table design mode - just to be clear.
Sure, in Table Design Mode (Field Dialog Panel) is set to Dutch(Belgium), verified also on right click on column heading in table view: Column Format and then Format Code: DD/MM/JJ
I have the same problem in BASE with locale English (Canada). changing the Date Acceptance Patterns to D/M/Y D/M etc also has no affect. using YYYY-MM-DD seems to work, but not ideal.
Open the Table, click on the header of the field and choose “Column format”.
This dialog should appear.
Which format will be shown there?
Date type
Custom date DDMMYY
This should be the format?
Then it expects 141225 for today (2025-12-14 in SQL code).
Now, 14/12/2025 with Libreoffice version v 7.5.5.2 on Windows 10, this bug is not more present. No swapping of D/M in a datefield. For me, this problem is version dependant.
