Newbie alert here. If this post is wrong or if I need to provide more info, please let me know.
I’m following some tutorials on how to learn LibreOffice Base. I’m using the following …
LibreOffice v5.1 Base
MySQL ODBC connector (latest)
MariaDB v10.0.20
Windows 10 Pro x64 (Running LibreOffice)
Windows Server 2012 R2 Standard (hosting MaraDB)
I’m having problems creating a subform.
I’m using the create a form wizard. I have added both my tables and joined the primary key fields (employee-ID). When I open and run the form, I get a dialog box asking for “Parameter Input” (see screenshot). I don’t know what to input, so I click OK. Then I get an error …
The data content could not be loaded.
SQL Status: 42S22
Error code: 1054
[MySQL][ODBC 5.3(w) Driver][mysqld-5.5.5-10.0.20-MariaDB]Unknown column 'ID' in 'where clause'
After clearing the error, the main form is populated with data. However, the bottom subform, has no data.
My question is, How do I get this subform to work, or how do I get rid of the “parameter input” dialog?
Here are some screenshots.
Parameter Input - dialog box to get rid of.
Main Form Window (edit: img not available)
Links (edit: img not available)
Form Properties (edit: img not available)
(edit: activated screenshots where available)
